aydeepee69
Message 1 of 2
BT Advanced Z not ringing when receiving incoming calls
Just replaced a BT Graphite 2100 with the Advanced Z
The handsets are set up fine but;
1. When I call it the call connects but phone doesnt ring
2. When I make calls on it, the number dials and the time counter starts - but there is no ringing sound
3. A line cord error keeps intermittently appearing on the display
I have reconnected the old phone and its back working fine
Any ideas folks?
1 REPLY 1
MurrayB
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: BT Advanced Z not ringing when receiving incoming calls
Hi aydeepee69,
First thing to try is to ensure that you have used the Linecord that came with the Advanced Z rather than any existing one you may have been using with the Graphite.
If that does not resolve the issue, please try removing and then re-installing the batteries on the Advanced Z handset to see if this resolves the issue for you.
