aarons11
Message 1 of 6
BT Baby Monitor 5" can't connect to BT Smart Hub 2
I keep getting error message 4 when I try and connect my iPhone 11 with the baby monitor, any ideas on how I can connect? I have tried turning off the 5ghz wireless on the hub, but that didn't work either.
5 REPLIES 5
imjolly
Message 2 of 6
Re: BT Baby Monitor 5" can't connect to BT Smart Hub 2
have you turned of smart setup
Turn Off smart setup
DavidM
Moderator
Moderator
Message 3 of 6
Hi @aarons11 and welcome to the community.
Have you had a look through the User Guide ? If that doesn't help there's also a number for the product support desk who should be able to help.
Cheers
David
aarons11
Message 4 of 6
Still the same issue, turned smart setup off and only the 2.4Ghz is on.
aarons11
Message 5 of 6
Looked through guide and as I have said I have tried a number of ways to make it work, but consistently get error code 4. I'm using a BT Smart Hub 2, which is connected to multiple other devices without any issue.
aarons11
Message 6 of 6
using IOS 14
