Newbie
Message 1 of 3
BT Broadband Discs
Hi
I have 2 BT discs set up in my home.
The hub is in our porch
Disc 1 is in the hall
Disc 2 is in my room
Each arent far from each other. Hoover i am working from home and probably for the foreseeable.
I would like to move across to our out house / shed. I can get wifi signal grom didc 2 out there but its too weak to hold video calls / remote access my wotk computer.
If i added another disc in the shed would this work? Will it weaken the wifi strenght across the house?
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: BT Broadband Discs
Are you able to move the hub and discs slightly so that the signal stretches?
If not, go for another disc. It won’t slow your Wi-fi down as they use mesh technology.
Recognised Expert
Message 3 of 3
What Discs Have you, and what is the signal strength on the slave discs , the App should give you the information.
