CianBond
Newbie
Message 1 of 4
BT Broadband Extender/Slave Hub
Hi,
I have a 'BT Business Hub 5' as my main router, the wifi doesn't reach to my workspace is it possible to use my old 'BT Business Hub 3' as an entension that can connect to my hub 5 and repeat the connection?
Any help is appreciated.
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: BT Broadband Extender/Slave Hub
Yep, turn off DHCP on the hub3, change its address to 192.168.1.50 and connect a LAN port on the hub5 to a LAN port on the hub3. If you don't want to run an Ethernet cable, you can use powerline adaptors to connect the 2 together.
CianBond
Newbie
Message 3 of 4
What is the DHCP and how do I turn it off?
Message 4 of 4
The hub allocates devices IP addresses using DHCP (Dynamic Host Configuration Protocol) as the hub5 will be performing this task it needs to be disabled on the hub3. I haven't got a hub3, but it will be somewhere in the advanced network settings.
