Message 1 of 2
BT Business Smart Hup port forwarding.
Hi All
I have a BT Business Smart hub (5 I think)
I have a range of useable static IP (5)
I have two webservers that I want to run of the two external IP, so
217.xx.xx.201:443 --> 192.168.0.10:443
217.xx.xx.202:443 --> 192.168.0.11:443
Is this posible?
I can set up Firewall | Custom configuration to allow  port 443 in on 217.xx.xx.201, and 443 in on 217.xx.xx.202.
and Firewall | Port forwarding to allow traffic comming in on port 443 to pass it over to 192.168.0.10.
But try to set up the second one and you get the error message "The port(s) are already in use by the rule:"
1 REPLY 1
Message 2 of 2
Re: BT Business Smart Hup port forwarding.
@David_at_TMTI
Welcome to the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
