Message 1 of 5
BT Business hub 2 - DMZ ip changing itself
Hi, I'm having an issue with my new BT business hub 2. I can see someone posted similar a year ago but got no response so not sure if it was resolved. So if anyone else has seen this issue...
DMZ worked fine on my original BT biz home hub 1 but on the new Biz hub 2 its changing the DMZ IP daily (or poss after I switch off the dealer board I connect and back on next day) Surely if I place a single IP into the DMZ this should stay as it is?
Regards
original post..
https://community.bt.com/t5/BT-Devices/Dangerous-DMZ-Bug-on-Smarthub2-Random-reassignment-of-device-...
4 REPLIES 4
Message 2 of 5
Re: BT Business hub 2 - DMZ ip changing itself
@KM78
Are you a BT Business customer?
Message 3 of 5
Hi Keith, thanks for reply.
I am, BT Business customer, static IP and was fine on Hub 1..thinking must be a setting here on Hub 2 but nothing obvious sticking out and tech help couldn't work it out. I'm right in thinking DMZ should remain what I put in yes? I was careful to place the IP rather than pick the device... reset router to double check and still doing the same
Thks
Message 4 of 5
as a business user you need to post here as this is for residential customers and will not have same hub as you
https://business.forums.bt.com/
Message 5 of 5
Thank you
