Calendar44-56
Message 1 of 6
BT Decor 2200 incoming ringer call set to high but only ringing quietly
Hi, I have a BT Decor 2200 set for high ring for incoming calls.  It has suddenly gone very quiet and not the ring I had chosen. I changed batteries but the same problem. I thought maybe the phone so purchased a new one. Set to high ring but very quiet again.
My phone provider is Virgin and they say the line is ok.
Any ideas please. I now cannot hear the phone unless I am in the same room.
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: BT Decor 2200 incoming ringer call set to high but only ringing quietly
Welcome to this user forum.
This is a BT Retail forum. You will need to contact Virgin Media so they can check their exchange equipment as it may be putting out a weak ringing current, which they would not see as a line fault. They have their own network  and terminal equipment, which does not involve BT Retail or Openreach. They will have to send someone to your house to investigate.
Calendar44-56
Message 3 of 6
Thank you.  Will go back to them again.
Von55
Message 4 of 6
Hi can you tell me where the ringer settings are?
Von55
Message 5 of 6
It was fine I just don't know where the ringer settings are
Calendar44-56
Message 6 of 6
Hi they are in the menu. Once I reach that option in the menu I can select the level I want, it gives me a test ring and I then confirm.
What I cannot understand is the test is very loud but when it rings on an incoming call it is very quiet.
thank you
