dkw
Message 1 of 5
BT Decor 2600
Received a text (?) message on the above device/landline. Stored as a 'Message' , but unable to delete. Only option appears to be 'Skip'?.
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: BT Decor 2600
Hi @dkw welcome to the community and thanks for posting, was the text message converted to speech and left as a voicemail on your answerphone? Or is it displaying as a text message on the phone?
Neil
dkw
Message 3 of 5
Re: BT Decor 2600
The text message was converted to speech and left as a voicemail  'Message'  which I can't seem to delete. Thanks.
NeilO
Moderator
Moderator
Message 4 of 5
Re: BT Decor 2600
@dkw Thanks for clarifying that, is the del button allowing you to delete other messages that are left on the answerphone?
Page 34 on the user manual explains how to delete messages, if that won't work you might need to follow the guidance to reset the phone but that, unfortunately, will also delete all the contacts and any saved settings.
Neil
dkw
Message 5 of 5
Re: BT Decor 2600
Now resolved. Reset device.
