garymarch
Newbie
Message 1 of 3
BT Diverse 7450 Plus Answerphone Problem
I'm having a problem with the answerphone on the Diverse 7450. Although the answerphone is switched on and the person calling hears the recorded message it is not recording. I have reset the machine numerous times but to no avail.
Any ideas what could be wrong?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Diverse 7450 Plus Answerphone Problem
Hi @garymarch
Welcome to the Community and thanks for your post!
Sorry to see you're having problems using the answerphone on your BT Diverse 7450 Plus.  Your best bet would be to chat to product support for that model of handset.  You can get the number on the >> BT Diverse 7450 Plus user guide << Page 59 Smiley Happy
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
garymarch
Newbie
Message 3 of 3
Tried calling but just ringing with no reply.
