queenr
Message 1 of 11
BT Dual Band Wifi Dongle 600 - Windows 10 Install
Hi
I'm trying to install the driver for this Wifi dongle on an Intel NUC running windows 10 but the install dialogue does not have the option to press Next or Cancel after it starts. Installed the same driver on a Windows 10 laptop without issue. Anyone know to get around this  issue?
Cheers
R
Message 2 of 11
Re: BT Dual Band Wifi Dongle 600 - Windows 10 Install
Have you seen the help page http://bt.custhelp.com/app/answers/detail/a_id/45437/~/dual-band-wi-fi-dongle-600
It does not specifically mention Windows 10, so perhaps your laptop was upgraded from Windows 8, to Windows 10, and the drivers are still there.
Windows 8 drivers are on this BT link http://btsupport.custhelp.com/app/answers/detail/a_id/44173
queenr
Message 3 of 11
Hi Keith
I used the same windows 10 driver on both the NUC and the laptop and both were upgraded from windows 7 to windows 10 a while back.  Are you suggesting that I try the windows 8 driver instead.
Many thanks
R
Message 4 of 11
Well there is not a Windows 10 driver listed on the BT product website, so you could try the Windows 8 one.
If that fails, then its possible one of the BT Device experts, who post on this forum, may be able to help.
Coight
Newbie
Message 5 of 11
There is no Windows 10 driver listed on the BT product website
queenr
Message 6 of 11
Hi
I used the windows 10 version of the driver from here:-
http://bt.custhelp.com/app/answers/detail/a_id/45467/c/1243
Is this not the correct site to use?
Cheers
Message 7 of 11
Yes that is the right one, it was not listed on the page I looked at originally.
queenr
Message 8 of 11
Thanks, well that is the one that isn't working for me on the Windows 10 Intel Nuc but did install ok for me on a Windows 10 laptop.
Cheers
Message 9 of 11
Its possible that the NUC hardware is not compatible with the USB device.
I used to have a NUC (Novatech Pockit) until it overheated and failed. That had a wifi card inside already, but I removed it to improve the cooling. The units can overheat if you are not careful.
queenr
Message 10 of 11
Hi Keith
The NUC is working ok with it's internal wifi card, but I've bought a fanless case to transfer it too. The idea of using the usb wifi dongle was to have a back up, I know the dongle is working ok, I have proved it on a laptop. It is when I'm installing the driver that I get the issue with the installation dialogue where I cannot see the "Next" button (I could see it during the same install process on the laptop. I thought it was perhaps the screen resoltion on the NUC, I tried changing that to no avail. The only other thing I can think of is perhaps it's something to do with the default browser on the NUC is interfering with the installation dialogue.
Cheers
R
