Message 1 of 4
BT Essential handset not playing number tones
Hi
I have a BT Essential Digital Home phone handset that, all of a sudden, will not play the in-call number tones. This is important because I need them for incoming calls from my gates to open them ( by pressing the number 3). I've done factory resets and used another handset but nothing has worked.
Any answers?
3 REPLIES 3
Message 2 of 4
Re: BT Essential handset not playing number tones
Hi @Glatham2020
Welcome to our community.
It sounds like you have tried the steps we'd usually suggest, so I'd recommend giving the team a call on 0330 123 4150 so they can help with this.
Lesley
Message 3 of 4
This number I have tried before where an automated message means I have to go through fault tests on the line but it doesn't give an option for faults to a phone. Is there a contact method so I can speak to technical support directly?
Message 4 of 4
That would be the only number for our customer service guides @Glatham2020, but you could also try the messaging service, which is available on our Contact Us page.
Michael
