flybiffo
Message 1 of 3
BT Essentials Wi-Fi Extender 300 Too Many Redirects
Recently installed the BT Essentials Wi-Fi Extender 300.     Now all connected iphones using  google chrome report an error for both new and often used web sites.    This has never been seen before installing the extender:
 redirected you too many times.
ERR_TOO_MANY_REDIRECTS
strange but true......a solution gratefully received....clearing cookies tried but is not the solution.
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: BT Essentials Wi-Fi Extender 300 Too Many Redirects
Hi @flybiffo Welcome to the community and thanks for posting, can you try resetting the extender by following the below instructions to see if that fixes this problem?
1. Make sure the extender is plugged in and the power socket’s switched on (check On/Off switch on the top is in the On position)
2. Press the Reset button for one second. Give it a couple of minutes to reboot
If everything’s OK, the Power indicator will light up and then after approximately 20 seconds the Too close and Too far red lights will flash together.
See the extender’s settings card (on the back of the user guide and the extender) for default factory settings.
flybiffo
Message 3 of 3
Nope rebooting everything did not work, and I've since discovered that if I connect to the home hub on its 2 bar signal then I dont get this problem but when connecting to the extender then the error comes back.   Is the extender faulty ?
