sandimusic
Message 1 of 2
BT Extenders Flex 600 Kit - All lights on but no internet connection
Hi all,
I have purchased the Flex 600 extenders yesterday and tried setting it all up as described in the enclosed manual. All three lights (Power, Data, Ethernet) on both extenders were on after I was done. I have tried connecting several devices (one after the other of course) to the extender, including my youview box and a computer, but it always fails to establish an internet connection for some reason. I have repeated the setup several times, I have reset to extenders to factory default, I have tried different ethernet cables, but nothing seems to work. They are both plugged into wall sockets directly.
Can anyone help with this, I am running out of ideas?
Thank you
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Extenders Flex 600 Kit - All lights on but no internet connection
@sandimusic It sounds like you've tried everything but I'd recommend you get in touch with the Flex 600 helpdesk on the below details as they may be able to offer further advice.
By phone: 0808 100 6116
Monday to Friday 9.00am to 5.30pm
Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
