Message 1 of 2
BT Guest Wifi via Discs
I have recently got BT Business Broadband and have the BT Business Smart Hub. I also have several Wi-Fi Discs, as it was my intention to use the BT Guest Free WiFi around the building to allow visitors to connect.
I have a good setup working with the discs, however they don't appear to broadcast the Guest WiFi, only the private network, and so in the above context don't therefore allow me to provide the guest WiFi around the building, as their advertising seemed to indicate I could do.
I have attempted to chat to an agent online but they couldn't understand properly my query and seemed to indeed indicate that the Guest WiFi does not work via the Discs.
Does anyone else use the Guest WiFi via the discs, or have I been mis-sold the product in terms of how its led me to believe I could when  its not possible?
1 REPLY 1
Message 2 of 2
Re: BT Guest Wifi via Discs
@Nick_HF
This is the BT Residential customer forum.
Please post on the BT Business Customer forum.
https://business.forums.bt.com/
I think this may have been asked before, and the discs do not repeat the guest Wi-Fi, but ask on the forum.
