Message 1 of 5
BT Home Hub 5 v BT Smart Hub
Hello
I have been using a BT Home Hub 5 for four years now and my experience has been very positive.
I have had little or no problems.
My network is hard wired so I do not rely on WiFi
However I now have acces to a brand new BT Smart Hub and i am wondering if it is worth replacing my trusty old BT Home Hub 5 ??
Opinions most welcome
Thank you
Edward
4 REPLIES 4
Message 2 of 5
Re: BT Home Hub 5 v BT Smart Hub
@efelstead
No, I would be inclined to leave things alone. If its not broken, then do not try to fix it.
Message 3 of 5
Absolutely, leave well alone.
Message 4 of 5
Thank you
Thats what I thought
I will keep the Smart Hub as a spare just in case
Message 5 of 5
I hear that they make great door stops or things to kick.
