Hi
I am/was hoping to use my BT Home Hub 6 as a wireless extender. I have switched off just about everything apart from Wi-Fi on the device. But I can't turn off broadband so it constantly clicks trying to connect.
On my main Fritzbox router I can turn off DSL if I want. But that doesn't seem to be any way to do this on the BT Home Hub 6. Any help would be appreciated. I either want to turn off DSL or just turn off the clicking. I have turned off smart set up and LEDs but that doesn't help.
Solved! Go to Solution.
You can't.
