Message 1 of 5
BT Home Hub 6 - no blue light
I have had problems with my BT Home Hub recently, and was sent another one (think it was refurbished). It’s all working fine but there is no blue light showing. When you re-start the hub it goes through all colours (green, & orange), then settles with no light on. I’ve gone to the BT Smart hub manager and hub light control status is “on”, brightness “100%”. Can you help resolve please?
4 REPLIES 4
Message 2 of 5
Re: BT Home Hub 6 - no blue light
If you think it is a reconditioned  hub did you try a factory reset by pressing the recessed button on back and holding  20/30 secs until lights flash
remember turn of smart setup when restarts
Message 3 of 5
many thanks. Can you just explain a little more about the last part of your advice please - "remember turn of smart setup when restarts".
Message 4 of 5
have you turned of smart setup
Turn Off smart setup
Message 5 of 5
BT advised that there must be a problem with the router and have now sent a replacement. All is well...... at least for now 🙂
