Hi
I have a BT Home Hun5. We have been decorating and the Hun fell on the floor and the little feet cane off the router. They aren’t damaged but I can’t get them back on! The router is working fine but it’s just that it won’t stand up. Can anyone tell me how to fit the feet to the router please?
Thank you
Clair
Perhaps BT will send a new router to you. Or purchase a new updated BT Router. Smart Hub or Smart Hub 2 from ebay.
Hi thank you they are sending me a home hub2. Are they better than hub5?
BT and some others think so, however if you are a user and used to splitting the2.4GHz and 5GHz bands, you are unable to do so on a BT Smart Hub 2
I use apple products and have found no problems with the BT Smart Hub 2
