Jack1092
Message 1 of 12
BT Homespot Boosters
Hi All,
I have a set of the boosters. I have noticed with my phone that it provides literally no wifi when i connect to it. My mum uses it and receives good internet coverage with it.
She has an Iphone and so do i?
I have tried speed tests and it backs this up. Is there anything i can do? Some settings or something?
Thanks in advance.
Jack
11 REPLIES 11
Message 2 of 12
Re: BT Homespot Boosters
Welcome to this user forum.
Are you a BT Broadband customer?
Jack1092
Message 3 of 12
I am indeed Keith.
Message 4 of 12
@Jack1092 wrote:
I am indeed Keith.
Thanks.
Which hotspot units do you have, and which BT home hub are you using them with?
Jack1092
Message 5 of 12
No worries!
I don't have that info to hand, i'm currently at my desk in work. I will come back to this thread at around 5pm with the answers.
thanks for the time.
Message 6 of 12
@Jack1092 wrote:
No worries!
That`s fine. Once I know which ones you have, then I should be able to offer some advice.
Jack1092
Message 7 of 12
Hi again,
The boosters are BT extender 600s + the router i am not sure- it says Hub6? Would that be it?
Message 8 of 12
@Jack1092 wrote:
Hi again,
Do you mean the BT Hotspot 600 units?
https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
If so, do you have just a single hotspot, or the kit with one main unit and two hotspot units which both transmit the same wireless network name?
Jack1092
Message 9 of 12
I have BT Hub 6 with 2 hotspot units which transmit from the same wireless network name!
This is it: BT Mini Wi-Fi Home Hotspot 600 Multi Kit (sorry not sure how to link it to you!)
BT Devices Expert
BT Devices Expert
Message 10 of 12
@Jack1092wrote:
Hi All,
Thanks in advance.
Jack
Hi @Jack1092 , do your homespot and home hub share the same wi-fi name? If so, that's probably why this is happening. When a device sees 2 networks of the same name, it's a little bit random luck which it'll connect to. Devices ought to connect to the stronger signal, but that can't always be guaranteed and is outside of the control of the wi-fi access point.
The way around this with homespots is to change its name to something different than the hub (for example, keep the default "out of the box" name). You can then use your phone settings to manually change to the wi-fi you want to connect to. It's a bit more cumbersome, but you're in control.
Does that address your scenario? If not, please come back and provide more detail so we can help further.
Device expertBrunoN
Show your appreciation!
Kudos”Kudos”
