BOGUS
Newbie
Message 1 of 3
BT Hub 4 connection dropping BT 1200 Wifi extender
Hi All,
I am a new BT customer and have the Hub4. to extend wifi range in my house i bought an Asus RT N66u and a BT 1200 wifi extender.
I conencted the asus to the network in repeater mode and the BT extender using the instructions.
they both worked initailly for 3 months but now they have stopped workinh. i ahve factory reset the asus and the extender but went through the process but no luck.
can anyone please help or point out what i am doing wrong ?
2 REPLIES 2
Message 2 of 3
Re: BT Hub 4 connection dropping BT 1200 Wifi extender
Try factory re-setting the hub4.
BOGUS
Newbie
Message 3 of 3
Thank you. It worked. I guess i was resetting all but not in the right order..
