NorthEasterner
Message 1 of 4
BT Hub 6 WiFi issue
Hi
I sold my BT Hub 6 (in June 2018) which was supplied by BT. Upon my contract being up and me leaving for another provider.  I never used the Hub and received it a month or 2 before leaving direct from BT.
The eBay buyer has now complained of WiFi issue and how the Smart Hub is not giving out a WiFi signal. The customer has a Type A SH6. Is there a known issue with SH suddenly stop broadcasting WiFi? If there is, any soloutions to the issue.
I should also note that it seems to be the Hub was working without issue for nearly 3 months until the buyer informed me on the second week of September.
Thank You.
NE
3 REPLIES 3
imjolly
Message 2 of 4
Re: BT Hub 6 WiFi issue
Not seen any problems with hh6 not providing a wifi signal especially if working when you had it
suggest turning off smart setup, splitting networks, change channels, change wireless mode
B13blues
Message 3 of 4
After you suggest they try those fixes i'd politely tell them that a second hand router that has worked for 3 months is no longer your problem. You've already done more than i'd do.
NorthEasterner
Message 4 of 4
Thank You both Smiley Happy
it seems the buyer has stopped communicating after 2 days.
Not my problem anymore as the device was sold working and has been working until now.
NE
