Message 1 of 9
BT Hub Model Name
My BT smart hub does not have it's model name on it - how do I find out the model name?
8 REPLIES 8
Anonymous
Not applicable
Message 2 of 9
Re: BT Hub Model Name
https://www.bt.com/help/broadband/learn-about-broadband/different-types-of-bt-hub
There may also be a clue in the SSID that the WiFi broadcasts.
Message 3 of 9
There are clues in the hub manager page.
What version of firmware does it have? Different hubs have different numbering schemes, if you post the version we can tell the version of hub.
Does have a toggle to set Full Fibre (FTTP) mode in Advanced settings > Broadband?
Message 4 of 9
Right, thanks for that, from the images it's a BT Smart Hub 2. I'm a new BT customer, moved over from Virgin. I needed to know the hub model for my next question 😁
Message 5 of 9
Hi
Firmware version: v0.41.00.07076-BT
Although this is a "smart" hub, I can't connect to the network with my 2.4GHz devices, only the 5GHz devices are recognised.  Though using different channels, both networks have the same name. I think it would be easier if they had different names to identify which is 2.4 and which is 5, but can that be done? Seems not, but under advanced settings, each has a QR code - is that there for manual differentiation?
Anonymous
Not applicable
Message 6 of 9
You're correct, the SSIDs for the 2.4 & 5GHz bands can't be split. All you can do is temporarily turn off 5GHz while you connect 2.4 devices. Otherwise you're looking at buying a WAP to provide what you need.
Message 7 of 9
Why 'temporarily turn off 5GHz' in this Hub? Why not leave it off if, your equipment has worked OK in the past without that frequency? In my 'experimental' SH2 from ebay I have turned off the 5GHz band and would keep it that way if I were actually using this device. However, I want BT to send me one when the switchover comes and so assume they could tell if I was already using a 2nd one?
Anonymous
Not applicable
Message 8 of 9
Because 5GHz is faster & less prone to interference from neighbours. But I suppose disabling it completely is an option.
Message 9 of 9
My current Smart Hub (6) has the ability to split the frequencies but my equipment is only firectrd towards the 2.4GHz band. No problems fir my needs.
