Message 1 of 8
BT Hub Problem?
Hi, I think my Smarthub 2 is going wrong.
I have 4 win10 pcs plus a Win10 tablet on my lan. Since last Thursday only two of them can access the internet. On the others I keep them flicking between the hub's ID with "No Internet" or "Unidentified Network".
I assumed this was a Window's problem so yesterday isolated all devices from the lan then, one by one, connected each Win pc/tablet , done a Win update, then disconnected. (Each one connected with no issue)
I then shutdown the hub for 10 minutes, restarted, did a factory reset, and switched off the WiFi.
One by one I connected the Window's pcs and finally the tablet. Each time I checked for internet connection and all were fine.
Finally I switched the WiFi back on and everything was good for the rest of the day, but this morning I'm back to square one!
A curious thing is that, looking at the hub, it shows my Win10 tablet as connected to port 4 for the wireless mac address.
I'm now lost to work out what to do. Help please.
7 REPLIES 7
Message 2 of 8
Re: BT Hub Problem?
Forgot to mention that the hub shows some pcs as having a static ips when windows show automatic.
Message 3 of 8
Re: BT Hub Problem?
if you did a factory reset of SH2  did you remember to turn off smart setup in hub manager
Message 4 of 8
Re: BT Hub Problem?
Nope. I'll give it a try now.
Message 5 of 8
Re: BT Hub Problem?
Sadly no difference
Message 6 of 8
Re: BT Hub Problem?
did you restart hub after turning off smart setup?
did you try selecting the wifi channels manually rather than leave on auto/smart.  I would use a wifi analyser on phone to see which channels are best for you
Message 7 of 8
Re: BT Hub Problem?
Yes I turned off smart setup before doing a factory reset.
My smartphones seem to be coping okay, its my wired pcs that are a problem.
My main pc is currently shut down with the ethernet disconnected. I thought about disabling DHCP on it and the hub then assigning what hub has its ip config statically.
Message 8 of 8
Re: BT Hub Problem?
Very interesting. After days of checking quite involved ethernet settings the only thing I was able to achieve was a WiFi connection from my only two PCs with built in WiFi. The others kept cycling between 'Network' -> 'Enabled' -> 'Unidentified Network'. The IP v4 Configs were in the 169.254 range which I understand is Windows "In House" addressing.
Yesterday morning, to my surprise, my network sprang into life when I started my PC and has behaved every since as if nothing had every gone wrong.
This comes on the same morning that I read an article on the BBC website regarding a Which report into the dire state of router security in the vast majority of router supplied by ISPs.
In my mind I suspect my router was hacked and BT applied a fix overnight.
