SeanMD
Message 1 of 2
BT Hybrid Hub
Hi, should I keep our Hybrid Hub permanently connected. Or should I only connect it up when Broadband is down?
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: BT Hybrid Hub
Hi @SeanMD and welcome to the community.
You can keep the Hybrid Hub powered on in case of any issues. Take a look at What is Hybrid Connect?
Cheers
David
