Message 1 of 11
BT INSPIRATION Business Phone
Hi all, I have a BT Inspiration Business Phone, it has standard RJ11 plug. Will this phone work on my Line1 connection on the FTTH Fibre box. My very old cordless did.
10 REPLIES 10
Moderator
Moderator
Message 2 of 11
Re: BT INSPIRATION Business Phone
Hi @SCS_Computer_Enginee  and welcome to the community.
Thanks for posting about the BT Inspiration phone. Can you just confirm if this is about a business line or residential line?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 3 of 11
This is about a residential line, using the BT Inspiration.
Cheers
Moderator
Moderator
Message 4 of 11
Thanks for getting back so quickly @SCS_Computer_Enginee .
If the cordless base station has the same RJ11 plug then the easiest way to find out if it will work would be to connect it. I don't see why it wouldn't work so give it a go and let me know how you get on.
Cheers
David
Kudos”
Carlusha
Message 5 of 11
It's been a while since I was able to use one of these 'phones. Now happily retired, you see.
It was my understanding that the BT Inspiration System functioned using its own special phones BUT, at the same time, ordinary 'phones could be used.
I believe the question is whether the phone you are bringing home is a specific Inspiration System model or an ordinary phone. Whether the Inspiration models work on residential systems or not, I cannot say.
Good luck.
Message 6 of 11
Thankyou
Distinguished Guru
Message 7 of 11
If it's a inspiration system phone it will not work on a pstn line. The phone works on a 4 wire circuit, 1 pair is for voice the other pair is for data that is sent out from the inspiration control unit.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Moderator
Moderator
Message 8 of 11
Thanks for stepping in @Devon_Dave .
@SCS_Computer_Enginee there's a few opinions on whether this will work or not. We'd really love to hear what the outcome is so as soon as you've tried please post back and let us know.
Cheers
David
Kudos”
Distinguished Guru
Message 9 of 11
Finally got round to check, should have done it sooner considering I have an Inpiration installed at home!!.
I can confirm as I thought If you plug a sytem phone into your PSTN line socket it will not work at all, No dialtone given.
DD
Message 10 of 11
Thankyou, I sent the phone back after doing some research, the Inspiration required a PSTN circuit board fitted inside. Which can be purchased for around £60. It's not worth it. It leaves me looking for a good business phone, I can use at home.
Rob
