Pjsaund
Message 1 of 6
BT Inspiration system
Hi everyone
I've just moved into my new home and discovered that I have no less than 22 phone sockets ....
6 of them are masters so I assume they are connected to (deactivated) direct lines
I've discovered a BT Inspiration phone exchange in a back room which (much to my surprise) seems to be working after being off for at least 5 years. All the other sockets now have a (slightly strange sounding) dial tone, but there's no outside line access as the exchange line is dead (being connected next week I hope).
The previous tenants (it was a commercial building) left some Featurephone handsets but for some unfathomable reason took all the power supplies.
So.... 2 questions
1) Do I actually need the Featurephone(s)
2) Does anyone know what voltage the missing PSU's are?
Thanks for any help
Tags (1)
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: BT Inspiration system
Hi @Pjsaund Sorry you have not received any replies. As this is a business product and this is the residential forum you may find you can get an answer on the Business Forum
In the meantime I have located the userguide which you will need Adobe to view and this may be of help to you.
cheers
John
Pjsaund
Message 3 of 6
Thanks, John - I've posted a similar question on the business forum - no replies there either.
Keith_Beddoe
Message 4 of 6
Its designed to connect via a 2Mb link, back to a FeatureNet exchange unit located in the local exchange. Its not going to be any use to you, as a residential user.
Pjsaund
Message 5 of 6
According to the manual it can be connected to PSTN lines (1 to 6 depending on the options fitted)???
Keith_Beddoe
Message 6 of 6
Featurenet can handle single exchange lines as well. Not sure how popular it is these days, as when I retired, many companies were moving over to VOIP, that was nearly eight years ago.
Many of the local exchanges has FSUs in them, but I would imagine most of these are now obsolete.
Phones were a mixture of analogue and digital types.
