Welshmatt983
Message 11 of 12
Re: BT Mini Connectors
Yes it works fine in another room, something to do with wiring it looks like, the room was an extension built onto house, not sure whether that has anything to do with it, dont think so as the daughers room above it also part of extension and works fine.
Moderator
Moderator
Message 12 of 12
@Welshmatt983 it could well be the reason as we've seen similar issues before if the sockets are on different wiring  rings.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
