Welshmatt983
Message 1 of 12
BT Mini Connectors
I have had 3 set up for a few months, I cant seem to add a 4th without one of the others dropping off, can anyone help??
11 REPLIES 11
Moderator
Moderator
Message 2 of 12
Re: BT Mini Connectors
@Welshmatt983 are you following the advice on page 9 of the mini connector userguide?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Welshmatt983
Message 3 of 12
Hi yes I have had set up 1 connected to router plus 2 extras, I had 1 spare which I wanted to use however cant get it paired like the others
Welshmatt983
Message 4 of 12
Is it worth resetting them all and trying again 1 by 1?
Moderator
Moderator
Message 5 of 12
@Welshmatt983 have you tried resetting all the connectors to factory settings and then pair them up again?
Kudos”Kudos”
Moderator
Moderator
Message 6 of 12
@Welshmatt983 I was typing a reply to you so missed your post, yes that's what I would recommend you try.
Kudos”Kudos”
Welshmatt983
Message 7 of 12
All sorted now, had no problem pairing, the problem was the actual socket it was in I noticed was no data light on.
Basically I have sockets inside chimney breast in back room about 3 double sockets side by side with a master switch on side of breast, I tried each socket and no data, last one I tried furthest right (closest to master switch) data light lit up feeling relieved now it has been stressing me out over past 24 hours!
Welshmatt983
Message 8 of 12
Well it is sorted but finding data dropping off every few minutes, any advice on this?
Moderator
Moderator
Message 9 of 12
@Welshmatt983 I'm glad you got that sorted in the end Smiley Happy
They are reliant on your electrical wiring so there must be something that is stopping the data being carried to those sockets.
Kudos”Kudos”
Moderator
Moderator
Message 10 of 12
@Welshmatt983 can you try the third connector in another socket in a different room? It sounds like it could be the electrical wiring causing these problems.
Kudos”Kudos”
