Message 1 of 2
BT Mini Hub 4G not working properly
Basically, I have been sent a 4G BT Mini Hub whilst my actual BT router is getting fixed. However, when I connect the Mini hub to my Xbox One, it says the NAT type is strict and it won’t let me go online. I don’t believe there is a way to access the hubs’ router settings, so I can’t even enable UpNp. If anyone can help, I’d gladly appreciate it
1 REPLY 1
Message 2 of 2
Re: BT Mini Hub 4G not working properly
Welcome to this user forum.
Because it works over the BT Mobile network, you will not get a unique IP address, as the IP address will be shared with lots of other users (CGNAT). Therfore it will not be possible to get open NAT.
 https://en.wikipedia.org/wiki/Carrier-grade_NAT
