Message 1 of 3
BT Mini Hub
sorry if this has been covered before but what's the main difference between the Mini Hub and the Wiifi extenders (610 & 600).
I'm trying to get a better signal in the upstairs rooms of my house.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Mini Hub
Hi @uktriathlete and welcome.
There's isn't a huge difference between the extenders and the Mini Hub. My own preference is extenders.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 3 of 3
Re: BT Mini Hub
