lucklylemon
Message 11 of 17
Re: BT Mini Whole WiFi - Ethernet Backhaul Setup
That's my experience as well
Jim-lad
Expert
Message 12 of 17
@jonnyollet  Understandable as you were trying to use it as never intended.
lucklylemon
Message 13 of 17
@Jim-lad, I am happy to follow steps to get this set in the right way. Can you give us advise please?
jonnyollet
Message 14 of 17
@Jim-lad how so? I wanted an ethernet backhaul like lucklylemon.
I tried connecting via ethernet two discs back to the router but the switching between the discs was slow.
I have also tried an additional switch between the router and two discs, but there was not any improvement.
Maybe I have missed something obvious, but I could not get the ethernet backhaul working. To be fair, the wireless works absolutely fine so in the end I have up.
Jim-lad
Expert
Message 15 of 17
@jonnyollet  what is the advantage of using the backhaul channel as opposed to using it in standard mode.
lucklylemon
Message 16 of 17
My disks located far away from each other, so on wifi mode they are rarely blue, mofe often yellow and sometimes even red.
Jim-lad
Expert
Message 17 of 17
@lucklylemon  so in Ethernet backhaul mode how does the system actually work then? Secondly can you not add additional disks.
