Message 1 of 4
BT Mini Wi-Fi Home Hotspots 600
This may be a silly question, but are the Mini Wi-fi Home Hotspot 600's dual band ? If not, assume they are only 2.4 GHz, is this correct ?
3 REPLIES 3
Message 2 of 4
Re: BT Mini Wi-Fi Home Hotspots 600
With a speed of 150Mbps on the WIFI side....I would assume the same. It does have 802.11n which can be used on the 5Ghz band but I would be surprised if it did utilize this given the speed it advertises.
The 600 refers to the Powerline top speed I think, which I would be astounded if it even makes half of that!
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 3 of 4
They are 2.4Ghz only.
Message 4 of 4
Thank you.
