oakserver
Message 21 of 37
Re: BT PREMIUM WHOLE HOME WIFI - ISSUES
I'm tempted by the premium 3 set - I would be using ethernet backhaul.
 @kevin_marchant Are you still having problems with these units on backhaul and no 2.4 ghz band or have they stabilised?
Tags (1)
kevin_marchant
Message 22 of 37
Still have a problem. It's with second line support currently.
cameron1975me
Message 23 of 37
I’ve given up on these, way too unreliable. For the price I expected better.
Got the Netgear Orbi RBK50 twin pack instead. So far so good 😊
Sircoynie
Message 24 of 37
Add me to the list of very annoyed customers with lots of disconnect issues.
One thing I have noticed in the logs is that when a disk disconnects the master resets the SSID to the factory default setting. I am wondering if I reset all the disks to factory default and don’t change any SSID/Password this will fox the disconnect.
Anyone tried this?
lnajr02
Recognised Expert
Message 25 of 37
nchaundy
Message 26 of 37
Hi, I am having similar issues with BT premium whole home Wi-Fi.. with discs dropping off the network and having to re-start regularly..
I have a BT Hub6 with 4 discs
is it best to raise a log with help desk?
lnajr02
Recognised Expert
Message 27 of 37
Who is your broadband provider and what hub are you using?
lnajr02
Recognised Expert
Message 28 of 37
Yes the help desk has been told that new firmware for premium is due. But that don't have the date yet.
nchaundy
Message 29 of 37
Broadband is BT
BT hub 6.
I have the hub 6 Wi-Fi still on..
I have had issues with Sky boxes disconnecting so have sky q and 2 of the 3 mini boxes connected to discs via Ethernet..
not sure if issues are to do with 5g channels trying to be used by sky and BT discs?
lnajr02
Recognised Expert
Message 30 of 37
I have been told that Sky Q takes most of the channels so any mesh system on the same network has problems. But I can't prove it
