Message 1 of 13
BT Premium Phone - Answer Phone Problem (doesn't disconnect)
Hi
I have an annoying problem with my answer phone. (I have the BT Premium Triple Handset Pack.) When a person leaves a message the answer phone doesn't disconnect. This means that only one person can ever leave a message. The only way to clear the line is to switch the power to the base unit off. It then re-synchronises with the handsets. (Once the power comes back on the time and date are wrong, but after a few minutes it then displays the correct time again.) The call blocking works really well but this issue is a pain. I've seen elsewhere that it may be that the caller's supplier hasn't sent the signal to disconnect when they hand up. Surely there must be a way round this? An answer phone that doesn't work is very inconvenient. Thanks in advance for any advice.
John
12 REPLIES 12
Message 2 of 13
Re: BT Premium Phone - Answer Phone Problem (doesn't disconnect)
@JohnBobin
Who provides your phone service?
Message 3 of 13
BT. (They also supply my Broadband.)
Message 4 of 13
That would seem to indicate an issue with the exchange equipment.
Does NU (number unobtainable) tone appear when the caller clears down?
Does it happen on every person that leaves a message?
Message 5 of 13
When this happens, there is no NU tone. The handset says "Fred Bloggs leaving msge" and a circular icon (with an R in the middle) goes round and round until you pull the plug on the base unit. It won't clear down any other way.  However, I just phoned my landline number from my Vodafone mobile, left a message and it disconnected perfectly. Somebody else tested it with a Tesco mobile and that worked too.
Message 6 of 13
Then the problem is with the calling party exchange equipment not sending a "clear" condition.
Do you know who is the provider of the person who`s incoming calls never clear?
There was a very similar post on this thread, but in this case the customer was on a different provider.
https://community.bt.com/t5/Landline/Problem-with-answer-phone-on-BT-Premium-Phone/m-p/2128915#M7507...
If it was doing it every time, then I would suggest a fault on the line card in the BT Exchange, assuming you are on a normal copper phone line connection.
Message 7 of 13
Thanks Keith
I will keep a log of which callers cause this problem and ask them who they use for phone services.
Message 8 of 13
@JohnBobin
Have you identified the issue yet?
Message 9 of 13
Hi Keith
The problem doesn't seem to happen so often now. However, I think your comments above hit the nail on the head.
John
Message 10 of 13
@JohnBobin wrote:
Hi Keith
John
Thanks for the update 😀
