Message 1 of 10
BT Premium Phone Answerphone messages
When an answerphone message is left , is there any way of detecting that there is an unheard  message on the  other base stations for the additional handsets. I know that the handset shows a message  on its screen when you pick it up. but the screen goes blank after a few seconds.
Many thanks
9 REPLIES 9
Message 2 of 10
Re: BT Premium Phone Answerphone messages
Hi @dephead2004 welcome back to the community and thanks for posting. Page 35 on the user guide explains how you can check and listen to answerphone messages on the handsets. I hope that helps?
Neil
Message 3 of 10
Thanks NeilO but my question was how to see there is a message on the phone (no base with or without answerphone) when it's resting.
So I come in and look to see if there's a message and I see a blank screen or clock. There's no indication that someone nice has left me a message.
UNLESS I pick up the handset then it show a message.
Is there any way of showing that there is a message at a glance?
Message 4 of 10
@dephead2004 I don't believe there is a way to do that without picking up the handset, sorry.  You can set an alert and the base will beep at intervals to let you know there's a new message if that helps?
Neil
Message 5 of 10
Yes that might really help as an audible reminder. Thanks. Good thought
Message 6 of 10
@dephead2004 no problem at all.
Neil
Message 7 of 10
Can I just come back to you NeilO on the audible warning. I have set handsets to on  under Settings/sounds/Alert tones/Voice message/on but the only audible tone is from the base station
Am I doing something wrong please?
Message 8 of 10
@dephead2004 No, I don't think you're doing anything wrong as that's what the user guide recommends. It may be worth talking to the premium phone helpdesk on 0800 145 6789 as they may have an alternative solution.
Neil
Message 9 of 10
Also tried them but no joy.
Message 10 of 10
Hi @dephead2004 I haven't used that particular phone myself but I presume it is working as intended and the features you are trying to use aren't available on it, sorry.
Neil
