Albie4464
Message 1 of 3
BT Premium Phone phonebook
I have a problem with my BT Premium phone phonebook deleting entries.
In my BT premium phone phonebook I have several duplicate entries which I wish to delete but am having to delete them individually is there a way to do a block delete?
2 REPLIES 2
DavidM
Moderator
Moderator
Message 2 of 3
Re: BT Premium Phone phonebook
Hi @Albie4464 and thanks for posting.
I found this in the user guide which might help.
Deleting contacts
1. Press to get to your contacts
list.
2. Use to scroll through to the
name you want to delete and press
Left option button .
3. Then press Down on the
button to scroll to Delete. Press Left
option button .
4. When you’ve gone through the
list, press Left option button
for options and then again to choose
Delete Selected.
5. You’ll be asked to confirm, press
Cheers
David
Albie4464
Message 3 of 3
When you do that it won't let you select another contact without first deleting selected contacts first then goes back to the start of the list I'm afraid at least that is what happed to me
Cheers and thank you
