stu1102
Message 1 of 3
BT Premium Phone
Hi
We have a BT premium phone we recently purchased we have forgotten the call control PIN is there a way of re-setting this
https://shop.bt.com/products/bt-premium-phone---three-handsets-090632-D93X.html
thanks for any guidance
2 REPLIES 2
VeteranISPUser
Recognised Expert
Message 2 of 3
Re: BT Premium Phone
Hi @stu1102
I suspect you are going to have to reset your phone and set it up again. If you contact the product help desk then they should be able to advise you. See page 44 of the manual.
http://bt.custhelp.com/app/answers/detail/a_id/60852/~/premium-phone-100%25-nuisance-call-blocker
stu1102
Message 3 of 3
many thanks solved it by ringing BT Product line as you suggested
