VeteranISPUser
Recognised Expert
Message 1 of 2
BT Premium Whole Home Wi-Fi Quick Questions
1. Can you change the SSID & Password?
2. Can you split the 2.4 & 5 Band SSIDs.
1 REPLY 1
Marcel
Message 2 of 2
Re: BT Premium Whole Home Wi-Fi Quick Questions
1. Yes you can set your own SSID and password.
2. No you can't. If you're having trouble pairing a smart 2.4GHz device to your Whole Home Wi-Fi network due to a conflict with 5GHz, you can temporarily enable 2.4GHz-only mode. Turning on 2.4GHz Device Setup Mode will disable 5GHz on all discs for 30 minutes or until you turn it off.
