Had to replace BT100 cameras BT no longer supporting. Trying to detup new Smart Home cameras . But app saying unable to find camera in pair mode. error code 1001. Camera is showing connected on wifi? Restarted Hub, reinstalled app disallousioned .
Solved! Go to Solution.
Try turning Smart Setup off.
Have you tried to set it up as per the user guide?
Can you see the camera in Android or IOS
Hi,
Yesterday tried setting up using my wife,s iphone6 which is using software version 12.4.2 & set up the 4No Smarthome cameras in minutes with no issues.
The cameras have all also appeared on my iphone 7 which has software version 13.1.2. but when attempting to view each camera green lights changes to orange & states connection error.
Using IOS
Thanks for your reply, works on my wifes iphone6 & as yo suggested tried on my ipad & all works fine.
There as suggested is an issue with the App & latest IOS.
Kind Regards
Re :- BT Smart Home Cam.
Hurrah BT App updated All Now working
That’s great news just updated mine as well! Thanks for letting me know
