mrberta
Message 1 of 12
BT Smart Hub 2 Keeps disconnecting
This seems to happen most evenings between 9pm to 11pm. BT came down and said there was no issue with the router and also installed a new line yet the issue still happens most days. (BT Smart Hub 2)
21:33:39, 04 Jan. Upgrade and system start TR069
21:33:37, 04 Jan. System up
21:33:30, 04 Jan. 2.4G WiFi scan(Reason:boot)
21:33:27, 04 Jan. Hub has activated against the device management system
21:33:27, 04 Jan. 2.4G WPS feature enabled
21:33:27, 04 Jan. 2.4G WPA2 mode selected
21:33:27, 04 Jan. 2.4G WiFi UP
21:33:27, 04 Jan. 5G WPS feature enabled
21:33:27, 04 Jan. 5G WPA2 mode selected
21:33:27, 04 Jan. 5G WiFi UP
21:33:19, 04 Jan. WAN Auto-sensing last connection port: DSL WAN
21:32:39, 04 Jan. System restart, reason: TR69
21:32:33, 04 Jan. CWMP: HDM socket closed successfully.
21:32:33, 04 Jan. CWMP: HTTP authentication success from pbthdm.x.x.x
21:32:32, 04 Jan. CWMP: HDM socket opened successfully.
21:32:32, 04 Jan. CWMP: HDM socket closed successfully.
21:32:32, 04 Jan. CWMP: HTTP authentication success from pbthdm.x.x.x
21:32:32, 04 Jan. CWMP: session completed successfully
21:32:31, 04 Jan. CWMP: HDM socket opened successfully.
21:32:30, 04 Jan. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
21:32:30, 04 Jan. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 6 CONNECTION REQUEST
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: BT Smart Hub 2 Keeps disconnecting
@mrberta
Its BT that is forcing the restart via TR069, which is used for remote management.
Not sure why its doing it every night.
Its one of the disadvantages of using an ISP provided router, as you have no control over it.
mrberta
Message 3 of 12
roduct name,BT Smart Hub 2
Serial number,+091298+1926000383
Fireware version,v0.24.04.11017-BT (Sun Nov 1 22:23:06 2020)
Board version,R01
GUI version,1.71 05_06_2020
DSL uptime,0 days 20 Hours 1 Mins 7 Secs
Data rate,6.1 Mbps / 35.0 Mbps
Maximum Data rate,6.4 Mbps / 43.3 Mbps
Noise margin,6.2/6.3
Line attenuation,6.9/21.3
Signal attenuation,6.8/19.1
VLAN id,101
Upstream error control,Off
Downstream error control,Off
Data sent / received,2.1 GB Uploaded / 2.1 GB Downloaded
Broadband username,bthomehub@btbroadband.com
BT Wi-Fi,Active
2.4 GHz wireless network name,Pretty fly for a wifi
2.4 GHz wireless channel,Smart (Channel11)
5 GHz wireless network name,Pretty fly for a wifi
5 GHz wireless channel,Smart (Channel36)
Wireless Security,WPA2 (Recommanded)
Wireless mode,Mode 1
Firewall,On
Software variant,-
Boot loader, 0.1.7-BT (Thu Nov 30 09:45:22 2017)
mrberta
Message 4 of 12
Thanks for the reply @Keith_Beddoe  But this happens most days, why would they be force rebooting me everyday? I can get logs from other days if that helps
Keith_Beddoe
Message 5 of 12
No idea, I suspect perhaps there is an issue with the home hub, perhaps the configuration is corrupted?
You could try a factory reset of the home hub, to see if it helps.
mrberta
Message 6 of 12
I have done a factory reset many times and I still have the issue most days. I'm not sure if all error logs are the same code so once it does it again I will post the new entries
imjolly
Message 7 of 12
When you did the factory reset by pressing recessed button back did you hold button until the hub lights flashed ?  You would need to turn off smart setup after restart
looks like hub is trying to update firmware and failing
mrberta
Message 8 of 12
@imjolly How do I turn off smart setup? Will turning that off stop the TR69 disconnects? Or will I have to get another router to avoid this issue?
Also had one of these in my logs recently not sure what it is I can't find anything online for it "DoS(UDP Loopback)"
Keith_Beddoe
Message 9 of 12
The only way to stop the TR069 disconnects, is to use a third party router, BT has no control over that.
mrberta
Message 10 of 12
@Keith_Beddoe Ok thank you! I love my BT router but TR069 disconnects happen at the most annoying times! I'll look into a new router! Thank you for the information.
