Message 1 of 5
BT Smart Hub 2 - Removing Devices from WiFi
I recently disabled the 2.4GHZ mode on the WiFi but I also want to remove unused devices (like old phones, computers etc) but can't seem to find the remove button, is it even possible?
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub 2 - Removing Devices from WiFi
try going to hub manager then advanced settings then my network and you should be able to select and remove
Message 3 of 5
Problem is I don't see any kind of delete button unless it's only visible on PC maybe?
Message 4 of 5
I am using pc and definitely there is a remove button
checked MYBT app and there is no remove button so need pc
Message 5 of 5
Not a lot of point in any case, its just a list of devices that have connected at some point.
