Message 1 of 5
BT Smart Hub 2: WiFi issues
Is anyone having WiFi issues with the Smart Hub 2?
I've been running one without issues for a few years and the firmware updated to v0.30.01.08093-BT last month.
I now find that my devices tend not to maintain their WiFi signal as well and/or are less responsive at times then they were before.. and I understand recent firmware updates have played with the SH2's WiFi..
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub 2: WiFi issues
I have that firmware and don't have any problems with my WiFi including SKY Q
Maybe the firmware update didn't complete correctly so have you tried a factory reset to see if that helps your WiFi. Remember turn off smart setup after the reset
Message 3 of 5
@imjolly thanks for the suggestion.
I have now tried a factory reset of the Smart Hub 2 a couple of times and am still experiencing WiFi issues with mobile phones (more than one device)
I now have to switch the phone WiFi off/on frequently to regain connectivity or else I suffer a time out..
As these used to work without issues, I can only assume the firmware upgrade is somehow responsible. It is the only thing which has changed in my set-up.
Message 4 of 5
Did you remember to turn of smart setup after factory reset?
Message 5 of 5
Yes, I did.
