Message 1 of 3
BT Smart Hub 2 with EE 4G SIM router
Have run into problems with Openreach trying to install FFTP.  I'm told it may be six months before they can get permission to dig to the premises.
Currently running intermittent standard fibre FTTC on Smart Hub 2.
I don't have a BT Hybrid Connect unit, but I do have an EE 4G SIM router with an option for month-to-month contract.
Is it possible to run the EE router in conjunction with the Smart Hub 2?
Idea being when BT standard fibre FFTC fails, as is often the case, it will automatically switch to the EE router.
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2 with EE 4G SIM router
Nope, that won't work I'm afraid.
Message 3 of 3
thanks. then I'll try to get a BT Hybrid Connect unit.
anyone know if Hybrid Connect bandwidth is as good as other 4G SIM routers?
