butchy72
Newbie
Message 1 of 3
BT Smart Hub 2
If I factory reset my Smart Hub 2 will the firmware revert back to the original?  I know the settings will.
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2
It will stay on the latest firmware, only the user configuration will be reset.
butchy72
Newbie
Message 3 of 3
Re: BT Smart Hub 2
Thank you.
