Attheend
Message 1 of 16
BT Smart Hub 2
Can I replace the BT Smart Hub 2 with my old BT Hub 5 which gave much better coverage or will BT give me trouble?
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: BT Smart Hub 2
Yes, provided you do not have a G.Fast (Ultrafast connection).
BT do not care what you use, ever third party routers. But they only support BT Home Hubs.
Les-Gibson
Message 3 of 16
Re: BT Smart Hub 2
Not if you have Digital Voice or Complete Wi-Fi (the black discs)
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
Attheend
Message 4 of 16
Re: BT Smart Hub 2
I have BT Smart Hub 2 which is nothing but trouble, have to ethernet it which means can't use laptop downstairs.  Still have the BT Hub 5 which the 2 supposedly replaces and just want to know if I can uninstall the 2 and replace with the 5.  Will I still get support?
Les-Gibson
Message 5 of 16
Re: BT Smart Hub 2
Yes, if you're using a bt hub you will get support
NeilO
Moderator
Moderator
Message 6 of 16
Re: BT Smart Hub 2
Hi @Attheend I'm sorry to see you're having trouble with the Smart Hub 2.
Did you try the other wireless modes on the Smart Hub 2 to see if that helped with your wireless issues? Some devices work better on mode 2 so I'd recommend giving that a go.
Neil
Attheend
Message 7 of 16
Re: BT Smart Hub 2
As there was a speed problem as well as connectivity (dropping out) BT was contacted.  We were told the BT Smart Hub 2 is the best in the industry, all the reviews say so and we would have to use an ethernet cord which we haven't used since about 2012. No one mentioned other wireless modes or anything else. Could you explain please?  Would be much appreciated?
NeilO
Moderator
Moderator
Message 8 of 16
Re: BT Smart Hub 2
Hi @Attheend The Smart Hub 2 is the latest most up to date router we provide customers with. I'm sorry, I can't explain why this wasn't suggested previously when you spoke to customer services. Did you give it a try to see if it helped?
As you wanted to go back to the Hub 5 that worked without issue, I thought it could be a compatibility issue with older devices and the newer hub therefore suggested the wireless mode change to see if it helped. The link I posted previously explains what each mode does.
Neil
Attheend
Message 9 of 16
Re: BT Smart Hub 2
There are other people watching tv etc so will have to wait to try this out when it is quiet.  We weren't told a lot of things when we renewed our contract.  Guess it's our fault for not asking more questions.  I notice on the forum that many other people are having trouble with this hub.
NeilO
Moderator
Moderator
Message 10 of 16
Re: BT Smart Hub 2
@Attheend No problem, give it a go when its convenient for you and post back to let us know how you get on. Due to the nature of a support community, you'll only see posts from people who are generally seeking assistance with a problem. For the majority of customers, it works without a problem.
Neil
