Message 11 of 16
Re: BT Smart Hub 2
I have come to the conclusion that the Smarthub 2 is solid and reliable as a router but it’s wireless performance is poor and restricted. For example the inability to have separate ssid for 2.4 and 5 GHz.
Message 12 of 16
Re: BT Smart Hub 2
I won't be able to try the modes you suggested until the weekend.  Do you know if I have to return the old BT Hub 5 which I would like to keep if possible?
Message 13 of 16
Re: BT Smart Hub 2
The wireless is poor for us, never had a problem before.  Having to ethernet the laptop, router is upstairs, can't use laptop downstairs.  Driving me mad.
Message 14 of 16
Re: BT Smart Hub 2
Any equipment you received before 13 Dec 2019 is yours to keep.
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
Message 15 of 16
Re: BT Smart Hub 2
Thank you very much.  I would like to do a "Problem Solved" but don't see the box.
Message 16 of 16
Re: BT Smart Hub 2
Message 5 has already been marked as the Accepted solution.
