Message 1 of 4
BT Smart Hub Firmware Version v0.37.00.07084-BT
My hub rebooted today, at "04:34:42, 21 Oct".
The firmware version number went from v0.31.00.10253-BT to v0.37.00.07084-BT.
The build date of the new version is shown as Fri Jul 8 11:29:23 2022.
A Google search for v0.37.00.07084-BT comes up with:
Can I presume this is a brand new firmware version? Has anyone else seen it?
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub Firmware Version v0.37.00.07084-BT
Hi @antient
As far as I can see, it was first reported on Tuesday. Mine updated on Thursday from v0.35. It seems that yours missed out on 35.
https://community.bt.com/t5/BT-Devices/Smarthub-2-Firmware-latest-version/m-p/2257440
Message 3 of 4
@VeteranISPUser
Thanks for the rapid reply. I should have mentioned that this hub had been in “cold storage” for some time, until the previous and very old hub, with which I was quite happy, started acting up. I had tried it when I first got it, but didn’t particularly like it.
Yesterday afternoon I was forced to use it, and on powering it up it went straight from v0.17 to v0.31. The second update in 12 hours was a bit of a surprise.
Message 4 of 4
when you did factory reset by holding recessed button on back did you hold for 20/30 secs until hub lights flashed otherwise it will not factory reset
