Des2
Message 1 of 5
BT Smart Hub & Powerlines
Hi,
    Does anyone know if the latest BT Smart Hub works with the Simpler Networks powerline adapters model:HP200PT64BT2 ? Thanks for your help. Des
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub & Powerlines
Powerline adaptors have no knowledge of what they are connected to.
Des2
Message 3 of 5
But would the BT smart hub detect the powerlines and cause a problem?
Message 4 of 5
I think what @licquorice was saying was powerline adapters should work regardless of the router you choose
Message 5 of 5
Correct.
