Newbie
Message 1 of 7
BT Smart Hub6 - 'My Devices' not showing in Smart Hub Manager
I am a relatively new BT Broadband (Fibre Infinity) customer having signed up in May this year. I switched from Sky and before that had Virgin.
I quite like the Smart Hub Manager interface but I am unable to get the 'My Devices' screen to show any useful information. It reports zero devices connected to the Hub which isn't true as I have a number of ethernet and WiFi devices connected at the time. I've done a reboot and factory reset to no avail. Can you please advise? My Smart Hub 6 serial number is: +084319+NQ74250257 and Firmware version is: SG4B1000B540. Thanks.
6 REPLIES 6
Message 2 of 7
Re: BT Smart Hub6 - 'My Devices' not showing in Smart Hub Manager
Its an issue which has been reported many times before. Sometimes it can take a very long time for the device map to update. As long as things are working, I would not worry about it.
Newbie
Message 3 of 7
I have the exact same issue however I need to port forward for a specific device which I no longer can do as I cannot select which device for the port forward to attach to.
Please can we find a fix?!
Newbie
Message 4 of 7
I currently have 10 Plus devices on the wifi wirelessly and this is what comes up..
Message 5 of 7
You may like to try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
The other alternative is to use a diiferent router which costs about £35, and works without any problems.
Newbie
Message 6 of 7
I will try a factory reset however the router works fine so is there any other fixes for this issue?
Message 7 of 7
I would give the device you wish to port forward to a static IP address on the device itself, then you are not worried about seeing it in the network map.
