Message 1 of 1
BT Smart hub 2 parental controls
Hi,
I currently have a bt smart hub 2 and use parental controls to prevent my teenage son staying up till the early hours on any device he can find. Sadly he has found out that by simply turning the smart hub off and on disables the parental controls giving full access. Short of locking away the hub and socket feeding it is there anyway to prevent this, short of putting in a third party router?
I can do this but wifi coverage is better with the smart hub and separate WiFi disk than the 2 linksys system I have used previously.
